Choose language
Reviews
Add-Ins
The SprutCAM Add-Ins Manager is designed to control the many available SprutCAM addins. Add-Ins can be DLL's, VBA/JS-scripts or COM-objects that support the extended SprutCAM capabilities. One example of this is to link with an external application (for example: link to SOLIDWORKS to use it for geometry import) or to add menus/toolbars to external applications (for example: a SprutCAM Toolbar for Rhinoceros).
Alibre/Geomagic Design 3.0 AD_PRT, AD_ASM, AD_DRW, AD_BOM, AD_SMP, AD_PCF, AD_SCF, SLDPRT, IAM, IDW, IPT, IPN, STP, STEP, IGES, SAT, DWG, DXF, X_B, XMT_BIN, X_T, XMT_TXT
AutoCAD /
Mechanical Desktop
3.0 / 5.0 IGES
FreeCAD   STP, STEP, FCSTD
IronCAD 2013 / 2016   ICS.IC3D.ICSW.ICD.EXB
MegaCAD 2012 PRT
SpaceClaim   SCDOC
TFlex   GRB
Система Orphus
Live chat
Get a call
