What’s new?
SprutCAM X and SprutCAM X Robot 17.0.15 update sees addition of ROKAE Robotics and KAWASAKI robots
The update introduces a host of enhancements, compatibility with MOKA robots, and bug fixes.
Enhanced lathe operations and more in the SprutCAM X and SprutCAM X Robot 17.0.14 update
SprutCAM X and SprutCAM X Robot 17.0.13 update: enhanced 6D contour operations and more
SprutCAM X and SprutCAM X Robot 17.0.12 released: enhanced Plunge Parameters, Singularity Avoidance Angle & more
SprutCAM Tech Unveils Feature-Rich Update with SprutCAM X 17.0.11
SprutCAM X enhances Collision Avoidance and other features in the new 17.0.10 update
The update introduces enhanced functionalities, bug fixes, and improvements
New release: SprutCAM X 17.0.9
Automatic spindle direction detection There are concepts of Forward and Reverse spindle rotation in SprutCAM X. Forward spindle rotation is clockwise rotation, as in the screenshot, looking from the left side of the lathe from the [...]
Introducing SprutCAM X 17 and SprutCAM X Robot 17: CAD/CAM/OLP for the Next Generation Makers
SprutCAM Tech announces the release of new versions of its flagship CAD/CAM/OLP software products
New release: SprutCAM X 16.3.10
What's new: Developers updated the technology settings window for EDM operations. Also the output of CLdata command parameters for EDM has been updated. The update included the toolpath calculation for adaptive roughing waterline strategy. The input form for painting [...]
New release SprutCAM X 16.3.8
About the new release We added the Finish pass parameter to the Adaptive SC strategy. Finishing pass and offset in the Adaptive SC strategy In this update, we have added the Finish pass option [...]
New release SprutCAM X 16.3.6
What's new This release contains only bug fixes What's fixed Fixed a bug with editing the position of the axes of the machine Fixed a bug with SprutCAM X freezing when working with [...]
New release SprutCAM X 16.3.5
What's new Polar interpolation new working principle. New in polar interpolation mode This update fixed the ability to work in the mode when the rotary axis is positioned at an angle different then [...]
SprutCAM X 16.3.4
What's new New parameter in the Cladding 5D operation New in toolpath calculation in Clading 5D operation In this update, we have added a new Solid Model option for the Cladding 5D operation. It [...]
New in SprutCAM X 16.3.2 release
What’s new New constrained toolpath calculation mode New parameter and transition types in the Additive operation New in constrained toolpath calculation In this release, we have added a new toolpath calculation mode when working [...]
New in SprutCAM X 16.3 release
What's new Updated work with automatic lathes Updated 2D Contour operation: stock for levels, turning off contours New in working with automatic lathes in SprutCAM In this update, we have completed the [...]
New in SprutCAM X release 16.2
What's new Updated Hole machining operation: parameters, interface Updated the 5D operation on the surface New in Hole machining operation The interface of the Hole Properties and Create Hole windows has been updated. [...]
New in SprutCAM X 16.1.2 release
What's new MachineMaker: new interface, multiple robots support, the workpiece on the robot flange support; Added the ability to bind to the geometry of the machine when measuring with a tape measure MachineMaker Updates [...]
New in SprutCAM X 16.1.1 release
What's new New snap for positioning 3D fixture models: circle center by three points Updated visualization controls Added the ability to save groups of operations to a file New Snap: Circle Center In [...]
SprutCAM X v.16 release candidate
SprutCAM X v.16 We are proud to introduce you the new version of SprutCAM X! Currently it is a RC release. So, trial license is available to everyone. SprutCAM X v.16 highlights: New interface New RockSolid [...]
